Fishbreath
Jul 04, 2018Explorer II
Additionally, you should have a circuit breaker in-line between the panel and the controller and one between the controller and the battery.
This is how Solar City recommends setting up the system. They use mini breakers in a mini box.
At a minimum, you should have a switch that allows you to turn off the power from the controller to the battery. Some charge controllers mandate that the panel be switched off before removing the battery. (Your manufacturer may differ)
Bill
Bill
Having RV issues? Connect with others who have been in your shoes.24,382 PostsLatest Activity: Apr 23, 2026
