Rotaxxx's avatar
Rotaxxx
Installing solar, got a question...
Well I will make this as short as possible! Just bought a truck camper to take to the mountains when we go, we will be boon docking the whole time when we go. So I need to install a solar panel to keep the battery charged up. I took al the amp readings and did all the math and found I need a 100w panel to get me by. I ordered it up, also ordered a charge controller as well. To do the install I had figured I would just remove the wires from the battery, tie in the charge controller to the battery, then tie the wires that where previously on the battery to the load side of the controller. But then I got thinking when I am plugged into shore power there would be 12V coming from the load wires from the converter to charge the battery. So there will be 12v getting to the charge controller load side. Will it fry the charge controller for the solar panel? How does everyone wire up their solar panels? Thanks all!
  • Don't use the load side of the controller. Don't remove the TC main feed from the battery. Just connect the main controller output to the battery and the panel to the controller input. Done. No reason to adjust anything if plugged in.
  • I just put a new solar controller in mine and when plugged in it just shows the voltage from the converter. I haven’t run my generator yet with the new controller but I don’t think there will be any problem.
  • Usually the load side of solar controller cannot handle the current draw of you trailer loads. I don't use that part of mine.
    Just leave the load wires on the battery as they were. And add the charge wires.
  • Most charge controllers play together well. I might have solar, alternator and charger (shore or gen powered) all at the same time. Some solar controllers require special care, however.
  • I turn off the solar panels when plugged into shore power per Renogy's recommendation.
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 13, 2026
