1L243's avatar
1L243
Explorer II
Jan 22, 2021
Installing Solar
My 500 watt system of 5 panels will be on order soon. I have watched several install videos, almost all videos show the installer mounting the solar panel brackets by screwing into the roof. Only one made any mention of looking for trusses to screw into. My roof has 3/8" plywood sheathing. Is it necessary to find a truss or is screwing in the sheathing acceptable? Panels can be placed more precisely if you don't have to hit a roof truss.
  • Jshupe,
    Mine are aluminum angle screwed to the roof. I used just 3 screws per side. They are still in place.
  • I agree, JS. Break in the glass would be the only reason.
  • Jay58 wrote:
    Mine are screwed into 3/8 plywood thru a 6 inch long aluminum angle 2x2 with 5200 sealant/adhesive to glue down and seal fastener holes. Wires were attached to roof with eterna-bond tape ( no screw required)
    No plans to ever remove them!
  • Mine are screwed into 3/8 plywood thru a 6 inch long aluminum angle 2x2 with 5200 sealant/adhesive to glue down and seal fastener holes. Wires were attached to roof with eterna-bond tape ( no screw required)
  • My panels are screwed into 3/8 plywood. Four+ years now with no issues.
  • I don't recommend Z brackets because of the difficulty of panel removal if needed. Instead use 2 pieces of aluminum angle bolted together to form a Z, easy to remove panel.
  • You will be fine screwing into 3/8" ply. The usual procedure for a 3/8" ply with a rubber membrane is to use 3M 4200, Chemlink M1, or Dicor between the roof and the Z bracket, use #14-1" stainless pan head screws, glob some sealant on top of the screws, and not worry about them going anywhere.
  • .... I’ve read where some people have used something like Dicor or Liquid Nails between the roof & mounting brackets.....
Having RV issues? Connect with others who have been in your shoes.24,340 PostsLatest Activity: Dec 01, 2025
