Joe417
Jun 13, 2018Explorer
My home thermostat went bad with the same symptoms recently.
The click you hear(or should hear) is the relay opening or closing. We have a similar coleman thermostat in our 5th W.
I put a digital in out TC about 2 years ago. Much better thermostat than the Coleman. Unfortunately, you already ordered the same thermostat as a replacement. It works.
As far as matching the wires, Old-Biscuit supplied the wiring info. That's a fairly standard color code but rv manufacturers don't necessarily worry about the color.
If it is like my coleman, you may need to write down or take a picture of the wiring. My coleman has the color coded wires coming from the thermostat and attaching to different color wires, with wire nuts, about 6" inside the wall.
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 11, 2026
