hypoxia
Sep 09, 2013Explorer
dougrainer wrote:
The EMS system does NOT affect the NON controlled breakers. Non Controlled----You do mean the breakers that do NOT shedd when the EMS shedds --Correct? You have 120 power to the breaker panel---The 2- 50 amp breakers will each have 120 volts on 30 and 50 amp. I have NEVER seen a Intellitec EMS system show 50 amps when 50 amps is NOT available. You need to check the 50 amp breakers at the breaker panel for 120 volts. Doug
Line 1 120 VAC, Line 2 zero VAC at the intellitec 50 A breaker & also in the transfer panel from shore power. The breakers that shed power have 120 VAC (Washing machine, A/C units etc.) The non shed breakers (receptacles & inverter/battery charger) have zero VAC. Last night I put the inverter/charger on a shed line just to charge the battery which worked fine. Light still says 50A continuously.
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
