time2roll
Oct 01, 2018Nomad
Rustofer wrote:At a given voltage the battery will accept only so much power. If you were getting 4 amps from the alternator and 4 amps from solar... it is very possible if you remove solar the alternator would then provide 7 to 8 amps. Same or slightly less net power into the battery without the solar.
I do need to do some testing. I'm not looking to buy a larger solar panel, MPPT, generator or DC-DC charger. I guess my next step is to remove one of the "straws" to see if it was getting in the way.
