JiminDenver
May 30, 2015Explorer II
CA
With the three 250w polys the controller has no issues adapting to changing light. It did eventually adjust in the first 4 panels series test but I had gone to change the leads around so I didn't see it until I was studying the graphs last night.
Today I started out with a series test on the 230w poly and 220w mono.
This is a full chart with the watts
This without the watts for a better look at the numbers.
For a basis I ran the panels separately to see what they did on their own. First the 220w mono, then the 230w poly.
With the watts
without
Then I did a parallel test. No branch connector, I simple crammed both sets of leads into the controller terminals. It's not perfect as one set of leads is longer than the other but you get the idea.
After that I brought out one of the 250w and did a parallel test with first the 230w and then the 220w. Then I finish it with all three in series.
These were all in bright sun. I'm hoping for some over cast so that I can record the effect of the mono taking a dive on the rest of the array.
With the watts
without
Having RV issues? Connect with others who have been in your shoes.24,408 PostsLatest Activity: Aug 20, 2026
