MEXICOWANDERER's avatar
Sep 15, 2018
Interesting DC High Voltage Solar Meter
HiLetgo DC 6.5-100V 0-20A LCD Display Digital Ammeter Voltmeter Multimeter Current Voltage Power Energy Battery Monitor Amperage Meter Gauge with Built-in Shunt
by HiLetgo
Product description
Style:DC 6.5-100V 0-20A
Specifications:
Voltage: test range 6.5 ~ 100V
Measurement Accuracy: 1.0
Measurement speed: 2 times/s
Store Energy data when power off. Can be reset to 0
The blue backlight can be turned on/off manually
Test Range and Display format:
Active Power test range: 0~2kW
Energy test range: 0~9999kWh
Voltage test range: DC 6.5~100V
Current test range: 0~20A
Note:
This module is only suitable for 6.5~100V DC power.
This module is suitable for indoor, not outdoor.
Applied load can not exceed the rated voltage and current.
The wiring order can not be wrong.
Packing Included:
1 DC 6.5-100V Power 20A Power Multimeter
This meter has a built-in shunt. 0-100 volts to 20 amperes.
BUT the amperes are measured BEFORE a MPPT meter.
The direct readings from an array are interesting and the total accumulated kWh is not volatile. The meter and it's information is segregated from a panel battery amp hour display. So implied solar panel function or dysfunction screams out at a user. And yes, the voltage reflects high voltage from the panels and direct high voltage DC amperes thus watts from the panels. BEFORE they go into an MPPT controller.
I found this on AMAZON...$12.49 and free shipping
  • "My solar goes over 100 volts.... "
    This one may work for you, and a good price. Reminds me of the ones I used way back when.
    Voltmeter
  • Yep at my age I should be sitting back in a recliner, clutching a lite ale belching and watching the Flamefart 500 on the toob.
    Or extensively preparing a foot high Dagwood sandwich and then read the obituaries in the local paper.
    Bingo at the clubhouse?
    Practicing shuffleboard moves for next year's cruise to the Bahamas?
    Foolish movie directors actually pay money for extras that play the part of seniors in The Walking Dead franchises. They merely need to film in the nearest retirement home.
    Groucho Marx, famously quipped -
    "You're only as old as the woman you feel"
Having RV issues? Connect with others who have been in your shoes.24,396 PostsLatest Activity: Jun 23, 2026
