I have a 92 thor pinnacle.There is a toggle switch up front in the cockpit that turns one of the ceiling lights on in the middle of the coach.It has stopped working.I tryed another bulb from another l...
if the ceiling light also has a switch, try it in both positions why you try the up front toggle in both positions. Could be the light was ON and someone turned it off at the light fixture. If that does not work look for a 12 v blade type fuse. It could be in or near the main breaker panel.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 15, 2026
