I have a 92 thor pinnacle.There is a toggle switch up front in the cockpit that turns one of the ceiling lights on in the middle of the coach.It has stopped working.I tryed another bulb from another l...
Check to see if there is 12v at the light it self with your multimeter, if not go to your 12 volt house fuse panel not the chassis panel in the engine compartment and look for some thing that says 12v lights and check that fuse. If it is not marked check them all you will probably find a blown fuse there.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 15, 2026
