RoyB
Mar 25, 2014Explorer III
My pick would be the Platinum Cat but would most definitely look into venting outisde to help remove dangerous fumes.
I really like this idea as seen on Google Search...
In my smaller trailer I have really been wanting to replace the loud propane furnace which produces way too much heat for us with one of these HYDRONIC Water heater type registers.
This concept -
Heat registers can be mounted most anywhere you can run PEX hoses.
They also make all kinds of base board type registers as well
We supplement our trailer heat with OIL-FILLED ELECTRIC HEATERs and these are very safe to use in the trailers. No visible flames-burnt heat heat smell-no noise except maybe a click.
We found this low profile model on AMAZON - We also use one of these O2COOL 10-inch fans that runs from 120VAC XFMR, DC Plug, or internal D-CELLS... Perfect for sitting behind the low profile oil-filled heater to move some heates air around the trailer.
One guy on here has installed electric heated floor panels
Lots of choices....
Roy Ken
This concept -
Lots of choices....
Roy Ken
