noteven
Mar 26, 2014Explorer III
Handbasket wrote:
I'm fooling around with a version of Roy Ken's hydronic thing. Google such terms as 'water cooled PC'. I'm wanting it mostly for 'background heat' so the noisy furnace doesn't wake me up so often. The Tiger's small, about the same volume as a truck camper. A quiet, low-amp pump, a computer fan, a radiator, and my existing water heater may be the answer.
I've got an email in mow to one of the outfits to determine what change in water temperature I can expect from inlet to outlet on the radiator. And yes, I've considered the Propex as a replacement for the Suburban 16000 Btu howler. I may do it yet.
Jim, "All reports are now in, and it's official. Life is unfair."
Hi Handbasket - yes the rad mfg should be able to tell you the btu/hr you can expect based on inlet water supply temp and flow and fan cfm. I do have room for a couple of these...time to get the ciphers out
