brulaz
May 27, 2014Explorer
pianotuna wrote:
Here is one way to solve the basement problem.
Replace the return air grill on the furnace with a fan. On my rv that circulates warm "living space" air under the cabinets and pushes some air along the furnace duct work. I chose to use a dual window fan unit which is controlled by a mechanical thermostat that lives beside the water pump next to the outside wall of the RV.
The fan unit draws just 23 watts and works better than a 1500 watt fan based heater which I tried using inside the cabinet.
Excellent idea. That plus a vented propane catalytic heater should work just fine.
