3_tons's avatar
3_tons
Explorer III
May 02, 2015
Interstate 6v batts at Costco
I just purchased two 6v GC-2 batts from Costco but they have no data on amp/he rating. My previous Interstate 6v batts were rated at 232 amp/hrs. I wonder why the new batts have no amp/hr data??
  • 3 tons wrote:
    Yep the body is all black but they are labeled Interstate GC-2's so they may be a special run for Costco (??),
    If you want the truth weigh them. Interstate makes different CG-2 batteries. Well i should say ( " Has batteries made to there specs. They dont manufacture there own batteries")
  • 3_tons's avatar
    3_tons
    Explorer III
  • WEIGHT
    WEIGHT
    WEIGHT
    WEIGHT
    WEIGHT
    Fewer pounds = less lead = fewer plates = less A/H
    No one makes a cheapo golf car battery battery with thicker plates in the "me too" market
  • jrnymn7 wrote:
    "Polypropylene Ribbed Case"
    Hmmm, is that for your pleasure, or the battery's? (sorry, couldn't resist)
    NOW...... That's funny !!!
    And their sold in the Pharmacy department along side the KY battery terminal conditioner.
    Is the battery all black? If it is its likely 208AH. And would weigh 63LBs A 232 AH would weigh 67 LBs.
  • "Polypropylene Ribbed Case"
  • Are these the same ones? http://www.samsclub.com/sams/energizer-6-volt-premium-golf-cart-battery-group-size-gc2/prod6000037.ip
    •6 volt
    •Minutes at 75 AMPS: 122
    •20 AMP Hour Capacity: 232
    •Reliable Cycling Ability
    •Deep Cycle
    •Gang Vent Design
    •Polypropylene Ribbed Case
    •Post Type: UTL
    •Core Fee May Apply
Having RV issues? Connect with others who have been in your shoes.24,203 PostsLatest Activity: Feb 20, 2025
