time2roll
Dec 11, 2013Nomad
CPAP & tv are easy. 300w would serve you fine. I recommend two batteries but one might get you by. I am sure your CPAP will recommend sine wave or no inverter.
Microwave needs 1800+ watts of sine wave inverter and should have minimum four batteries to drive it. This gets a bit more complex and expensive.
I would try to do without the microwave or get a small Honda 2000 to run the micro and charge batteries.
If you really want to avoid the generator you are probably also looking at solar to recharge batteries.
It is your call. If you are inclined to do the project you will get lots of help and advice. Need lots of planning to see what will work best for you.
