beemerphile1
Dec 12, 2013Explorer
You need an inverter, not an inverter/charger.
A simple 400 watt MSW inverter should run most televisions and entertainment equipment.
You will need a larger inverter and lots of batteries and then a generator or solar for recharging if you want to use heavy loads like a microwave.
You can get a 12v adapter to operate a Resmed CPAP for $85 and for a Respironics it costs about $30. Many CPAPs can run straight from 12vdc with an adapter and is more efficient than using an inverter.
I suggest you sit back, get comfortable and use the search engine of this website. Everything you want to do is possible but you need to educate yourself on how all these things operate.
