wa8yxm
Dec 12, 2013Explorer III
One more thing... Mounting the inverter
Mount the inverter as close to the batteries as you can but NOT in the same air space (Compartment) make sure battery fumes do not get to the inverter (They do not mix well with electronics) and run 120 volt wireing to the bedroom. Put an outlet next to the bed which is different from the rest of the outlets in the rig (unless you use a transfer switch) IE: if they are white, cream or off-white, use a black or better yet red or orange outlet (Red/Orange, Emergency colors for Emergency power).
