wa8yxm
Dec 12, 2013Explorer III
They make generators you do not have to go outside for And please get an Inverter generator if you plan on running it after hours.
(Yes they are expensive... but worth it).
One figure you may need to know.. A pair of GC-2 (six volt golf care batteries, wired in series to give 12 volt) gives you about 1KWH of usable power at the overnight rate. You will loose about 10% if you convert it to 120vac using an inverter.
So you may want more battery.
