BFRD22's avatar
BFRD22
Inverter / Converter won't switch over when on Gen
So I've been having issues with my xantrex inverter / converter on working with my generator. No pass thru nothing, no charging. Nothing. Works fine on house and pole power. Just won't on the Gen set. I've tried 2 different Gen sets. With the same result. I have to use a seperate battery charger to charge the trailer batteries. Very annoying. Can't use inside 110 off the Gen Set either as it won't auto switch to shore line.
Looking for some ideas.
  • 3_tons's avatar
    3_tons
    Explorer III
    Based on your description I’d suspect the ATS that passes thru shore power OR genny power - this is the ATS that’s before the Xantrex inverter-charger...It sounds like power may not be getting to the Xantrex due to a faulty genny ATS..
    3 tons
Having RV issues? Connect with others who have been in your shoes.24,239 PostsLatest Activity: Apr 25, 2025
