I have the crimper on the way as well as a Bussmann 120amp breaker, I am getting ready to order the connectors and wanted to make sure these are the right size. They are not exactly cheep so want to make sure I got this right I need 2/0 connector for the 1/0 cable?
https://www.delcity.net/catalogdetails?item=909755I also found this socket to install in the bed to connect the camper to the truck batteries.
http://phillipsind.com/auxiliary-vertical-dual-pole-soclet.htmlWell that will not work the Socket is rated for 150amps but the plug that mates to it is only rated to 100amps.
