MEXICOWANDERER wrote:
AMAZON
AC DC Marine
Marine Grade 600A Power Bus Bar 600 Amps Bussbar, Buss Bar
Be the first to review this item
Price: $59.99 + $5.99 shipping
https://www.skycraftsurplus.com/14awgdlo2kvblack-1-1-1-1-1-1-1-1-1.aspx
Minimum buy will allow a 15 ft run of 2/0 DLO Cable
(4) Lugs
https://www.delcity.net/catalogdetails?item=909765
Red Cable Heat Shrink Tubing
https://www.delcity.net/catalogdetails?item=980735
Black Cable Heat Shrink
https://www.delcity.net/catalogdetails?item=980745
I'll buy the remnant length of your DLO cable
To repeat there are fewer people on earth as big of cheapskate as I and this is the way I DID go, and this is the way I will continue to go. I depend on my stuff to work. The quality of the DLO cable is priceless it makes Anchor and Genuinedealz cable look like poor relations.
30' length of this will pass 200 amperes with acceptable voltage drop. But the outback and your batteries would chuckle at 300 or 400 amps. You will see it instantly when the microwave works exactly as fast as it does on shore power. You could use the microwave and a coffeemaker at the same time.
Thanks, I ordered the lugs for the 1/0 connections for the charging circuit and bed plug and the 2/0 for the batteries. I will order the wire when I get closer to installing the batteries and inverter. I am going to get the charging circuit installed first with a junction box near the battery location with the battery isolator, switches and bus bars. The way things are looking I will have about 3' of wire, 18" from the batteries to the buss bar and another 18" from the buss bar to the inverter.
