S_Davis's avatar
S_Davis
Inverter AGM questions
I have been thinking about installing a inverter in my truck, either a 2000-3000 watt. I would use it to run small power tools, air compressor, an electric blanket when on the ferry system as you can't run your vehicle. I would also like to set it up to power a truck camper when we purchase one in the next couple years. What I would like to do is remove my rear seats in my crew cab and build a storage box that would house two to four AGM batteries and the inverter, I want to install a 12v plug in the bed to connect to the camper batteries to form a larger battery bank as well as a 120v outlet to power a microwave, coffee pot, hair dryer. Will it work, is charging AGM batteries from the truck an issue?
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jun 23, 2024
