RWDIII's avatar
RWDIII
Inverter amps question
I plan on upgrading my popup camper,to a new one with electric top.
I plan on running 2 series 27 rv batts.I plan on running a 6 guage wire to the truck batt with solenoid with switch and 100 amp fuse
that I can switch in or out.
My question is if the microwave load is 1050 watts or about 90 amps
and I switch in the truck batt and Idle the engine,will the load see the alt as a 4th batt and take 22.5 amps from each source.The alt is rated 155 amps,90 to 100 at idle.
  • As others said, no. That's in part because the long run of 6 awg wire will function as a current limiting resistor.
  • You have 3 batteries yes? Two 27s on the trailer and something in the truck.
    The microwave is 1050w input power or cooking power? Input power it will draw 90+ amps, cooking power it will draw closer to 120+ amps. If using a modified sine wave inverter the power will be reduced by 20% to 50% and cooking times will be longer.
    The long #6 will supply 20 to 50 amps with the balance coming from the two 27s. The truck battery probably will not discharge as the alternator should hold voltage above 13 volts at the front of the truck.
    For maximum transfer consider some shorter jump cables direct from the truck battery to the trailer pair. Look for #4 copper cables.
    Best to have 4x group 27 on the trailer to drive a microwave.
  • The load will not be equal. A starting battery has many more plates and will take the majority of the load.
    This is a case of "Never say never". While I wouldn't recommend it, you could test it with a short run. Go back right after and check the starting battery voltage. The starting battery has a limited reserve capacity and cannot hand deep discharge without immediate recharging (i.e. starting engine and time to recharge).
Having RV issues? Connect with others who have been in your shoes.24,367 PostsLatest Activity: Mar 10, 2026
