helix528's avatar
helix528
Inverter and Auto Transfer Switch
I'm working on a project on my 5th wheel to add an Inverter, with a Auto Transfer Switch. I am trying to make it as automatic and fool proof as possible. I want to power just wall receptacles, and not AC, Micro, Water Heater, Fridge, power converter etc. I've seen some installations where the whole RV is powered by the inverter, and they just shut off breakers for the items they don't want drawing power. I want to avoid this scenario and keep it all automatic. So my idea is to feed power from the one breaker that controls the majority of the plugs. I would pull the romex that is currently on that breaker, and wire it to the output load of the transfer switch, then wire the breaker to the AC Input 1 on the transfer switch, and the input 2 would feed from the inverter. See the attached diagram.
My biggest concern, is with this method, when running on inverter power, the receptacles are not behind the breaker. They are only running through the breaker when on shore power. Is the internal protections of the inverter enough, or is what I've mapped out not going to work?
I cant get the wiring diagram jpg to work, but you can see it here
https://www.dropbox.com/s/l1aadigxn7gwqps/Trailer%20Wiring.jpg?dl=0
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jul 02, 2026
