BFL13
Sep 21, 2014Explorer II
behengold wrote:
I'm considering a XANTREX 2000 WATT FREEDOM INVERTER CHARGER 81-2010-12 .I'd like to have all outlets available whether plugged in or not.will this allow me to do that? Does it take the place of the current inverter or add to it? Also I'm replacing my coach batteries.Considering a pair of T105 6v batteries or should I look into AGM batteries.Thanks!
Ihe inverter part of the inverter/charger can add to an existing inverter for some loads being done by one and some by the other inverter (such as small loads by a small watt inverter and big loads by the big inverter) but you can just use the new one to run everything if you want.
If the OP meant "converter" when he said "inverter" then the answer is yes the charger part of the inverter/charger takes the place of the existing converter. Unless :) you keep that so you can have more charging options in various scenarios most Rvers would not get into.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 26, 2025
