Ron3rd
Sep 21, 2014Explorer III
pianotuna wrote:
Hi behengold,
It may be cheaper to get a stand alone inverter and a stand alone converter. I believe the Xantrex Pro Watt 2000 is $355.00 at Bestconverters.
For the converter I'd look at Progressive Dynamics, or Iota, or Powermax boondocker.
I added a 30 amp female outlet in the shore power cord box. I plug in the cord, unplug the converter, and move the fridge to propane only. Then I turn on the inverter and all my outlets are powered.
I'd prefer 12 volt AGM jars in your situation.
Do you boondock a lot?
I'm doing the same as Don (got the idea from him) but installed a 15a outdoor rated box under the trailer that I plug my 30a shore cord into with a 15/30a adapter. I went with the 15a plug to allow me to plug standard cords in if I want to. I might change to 30a down the road. With this method, you need to turn off the breakers for the charger, switch the fridge to propane, etc, as Don mentioned. It's kind of a down and dirty way to power all your 120v outlets. As mentioned, I only have a 350w inverter (Samlex PST series) since I don't have a huge battery bank (2-24's) and just needed to power devices like TV's, stereo, etc. Works great for my use.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 26, 2025
