BFL13
Sep 21, 2014Explorer II
behengold wrote:
I have the magnetech 7300. I have the generator to charge the batteries with. I'm looking more for the convenience. I realize I won't be using the 2000W capacity on two batteries.Just looking for the ability to have my outlets live all the time. I figured I needed a big inverter/converter to feed through my existing panel. If there's a primer please send me the link.
If you got an inverter/charger that is properly installed you would indeed have the convenience of the inverter and also a way better charger for your new batteries than the 7300 is.
Also, an installed inverter charger is more convenient than the method of using your shore cable and having to shut off the converter etc. (The 7300 does not have a switch or plug in and its circuit breaker is probably shared with some outlets, so its CB is no good as the switch, meaning a change in that wiring is needed)
While many of us do it that way with the shore power cord, it requires remembering what steps to take each time and doing those things. It is cheaper that way, but not everybody wants to do all that.
If the budget allows and convenience is desired, IMO go for the inverter/charger professionally installed and then let the automatic transfer switches do it all for you.
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jun 23, 2024
