wa8yxm
Sep 21, 2014Explorer III
2KW of inverter should be enough to power all your outlets INCLUDING The microwave (Mine does just fine)
For that much inverter you should use not 2 T-105 in series but 4 in a series/parallel arrangement
Bat-ery
Bat-ery
You will note each Bat-ery pair = 1 12 volt battery (specifically a 4D) Threat them as such.
Oh and though some folks like to split the bank in two and switch between.. I do not, costs you battery life,, just wire the pair as you would a pair of 4D's (in parallel)
Source on battery recommendation: Xantrex owner manuals.
AGM Unless there is mounting or access issues that make servicing the batteries difficult... I recommend against AGM.. Too pricy no benefit in most cases.
Bat-ery
Bat-ery
Having RV issues? Connect with others who have been in your shoes.24,349 PostsLatest Activity: Jan 16, 2026
