brholt's avatar
brholt
Explorer II
Jun 04, 2013
Inverter and TV
This weekend I installed a digital TV/DVD in the camper. On AC it worked well, pulledin lots of TV stations and the DVD worked well. However, when I switched to 12 volts I had some problems. I have two different inverters, both I suspect are modified sine wave inverts as they didn't cost much and just plug into the lighter socket.
The 150 watt fanless one played the DVD but the TV had a hard time getting signals. Only the strongest channels came through and the others had pixelation or the TV complained about a weak digital signal.
The 140 watt one has a fan that runs all the time (very annoying). Everything worked fine with it however.
My questions,
- Are some msw inverters better than others? How do you know?
- I suppose I could get a pure sine wave inverter but most of these seem to be overkill as the whole TV unit only draws 65 watts. I was hoping for something small, quiet, and inexpensive.
- bottom line, any recommendations for this situation?
Thanks
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Mar 27, 2025
