beemerphile1
May 21, 2018Explorer
donn0128 wrote:
My guess they did NOT plug into a 50A 120VAC outlet, but a 50A 220VAC dryer outlet. If they did they need to be prepared to spend lots of cash fixing the mistake. Happens all the time, but its going to cost to make things right. Assume most anything electrical will be toast.
This is a 50a rig. A 50a rig has two 50a 120v circuits for a total of 240 volts across the two hot legs. Those that do not understand this are no help.
I tested the ground, neutral and each hot leg at the pedestal and in the MH breaker panel, all is as it should be.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
