BFL13
May 21, 2018Explorer II
Amazingly bad reviews here (lots of failures):
https://www.amazon.ca/Nature-Power-38326-Inverter-2000-watt/dp/B00CBEXUG4
Is there also a second receptacle for the microwave? Can the whole rig be put on original breaker panel, forget the inverter?
The gen ran the fridge when the fridge was in the inverter receptacle, so what else does the gen run and not run?
One reviewer said the charger still worked after the inverter part quit. The manual linked above must have how you get 120 to the charger (haven't read it yet) Did the charger get 240v?
What was plugged into the inverter receptacles and where did that go--sub-panel like Mr Wiz suspects?
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
