beemerphile1
May 21, 2018Explorer
time2roll wrote:
With two outlets for the fridge it would seem the system is not fully integrated into the electric system. You have two separate systems. This is why power does not pass through. You need another transfer switch to automatically select the correct plug for the fridge. Otherwise YOU are the transfer switch. Now with the inverter out of commission I am not sure if that inverter/transfer switch will work or not.
In the mean time the battery is desperate for a charge. Get a 10+ amp portable battery charger on the battery asap while you sort this out.
Eventually I recommend a replacement stand alone inverter for the fridge, separate converter to charge batteries, separate transfer switches to fully integrate utility power, inverter, and the generator. Reconnect wire as needed to make it all work proper as would be expected by a non-engineer user.
I understand what you are saying. I believe the rig originally had an inverter/charger but was replaced by the previous owner.
The refrigerator does have two receptacles to choose from but the microwave and another kitchen receptacle do not. The microwave and kitchen receptacle require the inverter and that is why I thought the inverter would be capable of pass thru.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
