beemerphile1
May 21, 2018Explorer
BFL13 wrote:
Amazingly bad reviews here (lots of failures):
https://www.amazon.ca/Nature-Power-38326-Inverter-2000-watt/dp/B00CBEXUG4
Is there also a second receptacle for the microwave? Can the whole rig be put on original breaker panel, forget the inverter?
The gen ran the fridge when the fridge was in the inverter receptacle, so what else does the gen run and not run?
One reviewer said the charger still worked after the inverter part quit. The manual linked above must have how you get 120 to the charger (haven't read it yet) Did the charger get 240v?
What was plugged into the inverter receptacles and where did that go--sub-panel like Mr Wiz suspects?
The microwave does not have any receptacle available other than inverter powered.
I did not run the generator so cannot answer.
There is a single pole 30a breaker going to the inverter from the main panel.
Nothing is actually plugged into the inverter, it is all hard wired. I did not find any subpanel downstream from the inverter.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
