BFL13
May 21, 2018Explorer II
OK I read the installation instructions in that manual linked above. (But not the rest) It has an AC input port and AC output ports for hard wiring besides the receptacles.
The AC input needs a 30a breaker (not supplied) so is that connected so his 55a charger can work from shore power? (120v I assume)
Is there a wire from the output port to the breakers the original inverter used or to a sub-panel?
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
