beemerphile1
May 21, 2018Explorer
BFL13 wrote:
OK I read the installation instructions in that manual linked above. (But not the rest) It has an AC input port and AC output ports for hard wiring besides the receptacles.
The AC input needs a 30a breaker (not supplied) so is that connected so his 55a charger can work from shore power? (120v I assume)
Is there a wire from the output port to the breakers the original inverter used or to a sub-panel?
It appears the output may go directly to the receptacles. The wires left the inverter and disappeared into a wall, no sub panel was found.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
