MEXICOWANDERER
Jul 02, 2015Explorer
Still a good price "TJ"! Did good. It ought to be the last ground fault interrupter you'll need to buy. When you need receptacles that stay tight for large amperage appliances go with Hubbell. If you need terminals for connecting wire, use 14.16 gauge #6 forked terminals. 100% easier than winding strands under screws. Need to double wire per terminal use 10-12 gauge. I proved this will an IR thermocouple measurement. Using forked (spade) terminals rather than wrapping stranded wire around screws results in much lower junction temperature.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: May 13, 2026
