Sam_Spade
Jul 02, 2017Explorer
neonjohn wrote:
I don't like to run the generator unless it will be on long enough to fully heat up.
Do you camp much in the winter time ?
10 minutes should be plenty, especially if it has a good load and it's not cold out.
Just the converter/changer provides a decent load if the batteries are down a bit.
When the morning low is 70 F, run your gen for 5 minutes under load.
Shut it down and check the temp inside the cover.
That's 5 minutes by the clock, not an estimate.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
