prstlk's avatar
prstlk
inverter, charger, battery bank add on for 5th whell
We have been full time going on 4 years in a 39ft dp. We have loved the inverter system using 4 6V golf cart batteries, and the Magnum power managment controller. After the purchase of a "winter" home in the SW, we are moving back to a 5th wheel, as leaving the DP sitting for 4/6 months makes little sense. We purchased a used 5th wheel with a 5500 LP gennie and my questions are as follows.
I would like to have similar system in the 5th wheel. Battery bank, inverter/charger etc. I'm getting bits and pieces here and there on the net, forum boards utube etc.
Does anyone know of a comprensive book that can walk me through what I need to do. I have wired several houses, and wires electricity does not scare me.
Thanks in advance for any help.
If I'm on the page please dear moderator move my post.
I can't begin to tell all how the place has helped me since 07!
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    I found the instruction manual for my Prosine was rather complete.. Still I had it installed by Camping world ... THey only screwed up two things on that install and two more on the oil change they did at the same time.. I AM NOT KIDDING.
    THe install is very basic, with only a few "TIPS" not in the manual
    First.. LOCATION LOCATION LOCASTION Since a big inverter draws BIG TIME 12 volt current you want it close to the batteries,, but NOT breathing the same air (Battery fumes bad for inverter)
    Next Whatever size cables they say to use (12 volt side) UPGRADE one or two sizes and for as much of the run as possible tape the positive and negative cables side by side (or use a split loom) I suggest red for the positive and black for the negative (Wire insulation color)
    So much for the 12 volt side of life.. Now the 120
    Determine what circuits you want INVERTER powered.. IN my RV that is the Televisions and related electronics,, GFCI chain and MIcrowave
    Put in a SUB PANEL and transfer these circuits to it,, IN many cases you can actually use the same breakers.. NOTE: Sub panels generally do NOT have a main breaker and also do not bond Neutral and Ground (Ever on that).. NOTE 2: In some cases the sub panel may be part of the inverter itself. Mine is not, I like mine better, If I trip a breaker I DO NOT need to go outside to reset.
    Replace one of the now unused breakers (or moved breakers) with a 30 amp, if you moved them block off the others for safety (Gorilla tape works well).
    10 Ga (or 8) from that 30 amp breaker in the main box to a 2,000 watt inverter/charger.. and a 2nd 10ga back to the sub panel. Use a sharpie to label them IN and OUT at the inverter..
    And that's all folks
    Oh Batteries.. One Pair GC-2 per Kilowatt of inverter, DO NOT FORGET THE FUSE
  • Do you know what size inverter you had in the DP? If that worked for you then install the same brand and size along with four 6 volt GC batteries. You did not say if you plan on installing solar panels. Four 160 watt panels work nice for you.
Having RV issues? Connect with others who have been in your shoes.24,330 PostsLatest Activity: Oct 30, 2025
