CA_Traveler
Apr 15, 2017Explorer III
Have you had a case when the alternator not keep up with battery charging? If there is a issue you could just turn the inverter off or it will shut down when the DC input is to low.
Is the refer an absorption refer that you run on AC when driving? 300W is a lot for modern res refers.
Or perhaps use a 200A continuous duty solenoid on the DC input to the inverter.
