dougrainer
Apr 15, 2017Nomad
A 1500 Watt Inverter will require a Cole Hersee 200 amp continuous draw solenoid. NOT ALL solenoids are 200 amp and not ALL 200 amp are rated for continuous draw. The activation fuse for this type solenoid is 5 amp. The FEED battery cable should have a minimum 150 amp fuse between the battery and the solenoid. Doug
PS, this is the setup Airstream B vans use.
