MEXICOWANDERER's avatar
May 21, 2015
Inverter Efficiency 99% ???
Just reading a White Paper about the new SIC MOSFETS and several European inverter manufacturers are claiming intertie efficiency as being >99%
This promises to be interesting for inverters even with a higher Delta T E factor.
Efficiencies with PSW well into the nineties?
  • Grid tie is 400+ volts in and 230 volts out so it will inherently be more efficient than any RV inverter pulling in 180 amps to make power.
    I also find European ratings in some areas are not quite as realistic as the US.
