KD4UPL
May 10, 2017Explorer II
If the inverter frame is bonded to the RV frame and your shore cord ground wire is also bonded to the RV frame I see no need for a ground connection between the Rv's plug and the inverter.
A inverter made for use both with shore power and stand alone, like the Outback VFX2812M will have a built in transfer switch that bonds the neutral when off grid and does not bond it when on shore power.
