Kountryguy's avatar
Kountryguy
Inverter for Samsung Refrigerator
What size inverter will I need t operate a Samsung Residential refrigerator? I will probably use a pure sine one so I can use it for TV, computer also. Thanks
  • C_B_'s avatar
    C_B_
    Explorer II
    My 21 cu. ft. Samsung runs off two 6 volt batteries with a Xantrex Freedom Xi 1000 pure sine wave inverter. The refrigerator is the only appliance that runs off the inverter.
    C.B.
  • Kountryguy wrote:
    I already have a 1500, I guess I will give it a try, and hope!
    "Hope" won't solve your problem, having a suitably sized inverter (which apparently you already have), a battery reserve capable of adequately powering that inverter, and a suitably sized means of recharging that battery bank will. So aside from the inverter, do you? :@
  • Most are getting 2000 watt inverters. Lets you use several things at once.
Having RV issues? Connect with others who have been in your shoes.24,311 PostsLatest Activity: Sep 05, 2025
