Gdetrailer
Sep 22, 2016Explorer III
ScottG wrote:2oldman wrote:
Oh, around 150-300w.
This will work fine.
Not even close..
Now if you are talking about a NON INDUCTIVE load like a TV that would not be an issue.
BUT, since the subject IS a highly inductive load that small of an inverter won't have a snow balls chance in a very hot place of attempting to start the compressor.
I MEASURED my home fridge conversion, running was 80W, BUT the startup surge was 10 to 11 TIMES the running wattage.
With that said, some folks have reported success with 700W inverters but I think that is very sketchy at best. Most cheap inverters have very short surge wattage, so short they don't bother listing the time..
With that said, you NEED at least 1000W inverter if you are going dirt cheap, that will at least get an inverter that has a continuous wattage rating ABOVE the startup surge...
DON'T SKIMP on the 12V wire size, go to the max the inverter will accept! AND KEEP THE 12V WIRE AS SHORT AS POSSIBLE!
For my home fridge conversion I went with a Tripplite PV1250.. That is an MSW inverter that IS designed to handle INDUCTIVE LOADS.. Yes, it is not cheap but I have confidence it will handle the fridge compressor without going up in smoke or burning up the compressor.
Having RV issues? Connect with others who have been in your shoes.24,393 PostsLatest Activity: Jun 12, 2026
