reckfield's avatar
reckfield
Explorer II
Mar 20, 2018
Inverter Generator and 12v deep cycle batts
I have an 89 Alpenlite trailer that has the original converter. I have two group 27 deep cycle batteries connected in parallel that I use in the trailer. I would like to know how best to charge the batteries while boon docking? I could hook the inverter gen to the shore line power cable. But, I'm thinking I would be much better off to connect a 25amp charger directly to the two batteries in the trailer, leaving the battery connections to the trailer in place or should I disconnect those while charging with the 25amp? From what I have read, the converter will never get the batteries up to charge as the converter will go into maintainance mode around 12.5 or less if using the shore line to the converter with the inverter gen. Thank for your help.
  • What amp rating does your current converter have? I would suspect it it much higher than the 25 amp charger you are considering connecting but I am wrong.....a lot!
  • I use a charger with my batteries and they get up to full charge faster than the TT electrical cord
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 15, 2026
