edekgb
Oct 06, 2015Explorer
JiminDenver wrote:
Have never heard of the lake but I'll add it to the list of places to check out. We are usually up near Jefferson and exploring our way down to 11 mile.
I would call the manufacturer and ask if they make the high altitude jets before you buy. Rejetting will have the generator running more efficient but it wont make up for the elevation completely. Unfortunately getting any parts for the lower end generators can be a issue so check that out too.
You can also call then and ask them straight up, this is the elevation I will be at, the A/C I will be using and we want to use YOUR generator. Will it do it? I also asked at rental shops where you could ask if 2000w will cut it from any manufacture.
Now if you do get it and it is almost there. Make sure the converter is off and maybe get a start capacitor for the A/C.
Last thing is it is the end of the season and the deals are to be had on craigslist. You could end up with a much nicer generator with little use if you watch.
I have emailed Westinghouse and asked them out right (good advice). Will let you know what they say.
I may try Craigslist but im a little worried about buying a generator used.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
