RobWNY's avatar
RobWNY
Inverter Generator Help Please
Recently I booked a 4 night stay at a State campground with no electric hookups for this upcoming camping season. It will be my first experience relying on just battery power. My Travel Trailer has the one Marine/Deep cycle battery and I have decided to get 4 Trojan 6V T-105's and wire them in Series and Parallel. I also plan on buying a portable Inverter Generator so I can re-charge the batteries during my stay. I will be conserving power of course and may not need to charge them up, but better safe than sorry. Anyway, there are a ton of them on the market now, each brand having slightly different features. Most of the ones with 3000w or more have an RV plug. Is buying a generator with that plug something I should consider? All of the videos I've seen reviewing them, are all about whether the generator will power the air conditioner. Since most campgrounds limit when and how long you can use a generator (Usually during daylight hours), I'm not understanding the appeal. Being able to run an air conditioner for a couple hours during the day wouldn't be of interest to me. We won't be in the camper then. Mainly, the generator will be used for topping off the batteries and charging cell phones. Is it better to charge batteries directly from the generator to the batteries using a battery charger or through the camper by using the RV plug? Thanks in advance for your thoughts.
  • For 4 days four-6V batteries sounds like overkill, I can go 2 days on dual G29 batteries and that's with a fridge vent fan running.
    If you have a WFCO converter your money may be better spent on upgrading it to a PD or IOTA.
    What's your power useage? Do you have LED lighting in the trailer?
    10 years ago I bought a Honda 2000i and never looked back. It runs everything except the AC.
  • Like you I've never seen much point for running the AC on a generator. I mainly need the AC at night to sleep when you typically can't use the generator. If I was going to just sit in the RV during the day with the AC on I'd just stay home. Having said that, my TC did come with a gen. and I have used it on occasion to run the gen. for brief lunch or child nap stops when traveling. If it wasn't built in (meaning I had to drag out and hook up a portable) I probably wouldn't bother.
    The Honda or Yamaha inverter generators are the only 2 that would get my money. Their reputations are nearly flawless. Everything else is a little cheaper, a little louder, and a little harder to get parts for, etc.
    Your RV converter should charge your batteries fine it's a fairly modern 3 stage design. Otherwise, a good external charger might be better. I'd probably just upgrade the built in unit before I spent money on a separate charger. By the way, the "battery charger" output on a generator is typically useless: very low power and poorly regulated.
    A 30A RV outlet on a generator is certainly a good selling point. I'd be fine with just a 20A however. I frequently camp at small campgrounds with 20A service and my AC runs just fine. I do turn it off when running the microwave.
  • Yeah,a single Grp24 battery will probably be a problem with a lengthier stay. If you do install 4 GC2 6V's you'll have a lot of capacity, probably enough to overnight for a couple of days. We don't know your exact usage, i.e. running a furnace for heat uses a lot of 12 V power.
    The built in RV converter should be a good charging source and operating a generator is a good time to use that available 120V AC. You could post up the converter model numbers for more focused advice. You can also use a stand-alone battery charger at the same time to limit generator run time. Assumed that the two charging devices charge the batteries quicker, together.
    The yellow Champion generators are a good buy, IMO. the Honda and Yamaha inverter generators are at the top of the list and have prices that match. I'd avoid Costco WEN generators or Harbor Freight knock-offs. Serviceability is questionable about those latter ones.
    If you have plans to camp off-grid occasionally, solar panels are like peanut butter and jelly with 12V systems. You do have to get Sun on them but a generator for back-up use is a good plan.
Having RV issues? Connect with others who have been in your shoes.24,338 PostsLatest Activity: Nov 27, 2025
