HighCover's avatar
HighCover
Inverter Generator Update?
My Yamaha Efi 2400 is 10 years old and I can't seem to get it to idle anymore, even after attempting to service it. So, time for a new QUIET generator.
Looking for recommendations for a quiet generator that will start am 11.5kBTU AC unit? I know Honda is very good, but are there any other options nowadays that are a bit more affordable?
Thank you for your thoughts.
- Dan
  • Champion inverter remote electric start
    The early model is 3100 peak, 2800 continuous, will run your A/C
    The models are 3500/3400 peak 3000 continuous, will run your A/C
    Around $1100 for the new models , a bit less for the 3100 model
    Hondas are great, but when running an a/c unit the sound difference is almost imperceptible to my ears
    Yes at idle in econ mode I think the Honda sounds a little softer
    I run a generator because I need it, not to let it idle at 2 amps powering the tv
  • HighCover wrote:
    Will a Honda 2000 start an 11.5k AC unit?
    It may. It will be quite a job to keep it running, and it will be loud.
    I'd suggest getting 2. Paired up they run just about anything with minimal noise.
  • Will a Honda 2000 start an 11.5k AC unit? I didn't think it would, because when I bought the 2400 Yamaha, that was the selling point. And to its credit, the 2400 did the job fairly well. But I'm done with Yamaha because their carburetors don't idle well, and they have virtually no service for generator products.
  • Hi,
    I'd go for the Champion with the remote electric start. I believe they make a 3500 watt model.
  • skipro3 wrote:
    I know my ears as they hear generators while walking through a campground and it's truly amazing how quiet those Hondas are.
    x2. They have conquered that annoying whirring noise that seems to carry a long ways.
  • It really is amazing that no one seems to be able to match the Honda 2000 inverter generator for noise. Regardless of the numbers in the specs, I know my ears as they hear generators while walking through a campground and it's truly amazing how quiet those Hondas are.
  • Although we have an Onan we purchased a Champion 3100 remote start inverter in anticipation of purchasing another rig which will not have an onboard genny. It has impressed me with it's performance and is very quiet by comparison. It is overkill for your needs but the Champion 2K watt inverter generators also have a good following and are more economical than blue or red. There are some other lesser known inverter generators that may be less expensive than a Champion but I think it unwise to take a chance on them, Champion has good US based customer service and plenty of parts availability.
  • More affordable= more noise. Many on here like Champion.
Having RV issues? Connect with others who have been in your shoes.24,349 PostsLatest Activity: Jan 16, 2026
