BFL13
Sep 30, 2013Explorer II
Using a low amp charger means running the gen extra long times, so you need lots of gasoline for it. So now another consideration is whether it has a fitting for an extra gas tank, or if you are using Jerry cans for that.
A single 100AH battery can take 30amps initial charging, so a 25amper would be way better than a 6amper.
Note that the 8amp DC output is 'dirty DC' not well regulated. When running that you don't use the 120v side at the same time. Unlike with a proper battery charger, where there might be some extra VA in the gen to run some other things in the rig at the same time besides the battery charger--especially as the amps taper.
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: Apr 27, 2026
