BFL13
Sep 30, 2013Explorer II
Your morning voltage will drop every day until it gets to about 12.2 (with a 12v batt--12.1v for a pair of 6v) then it will be at 50% and needs a recharge. Charge till the charger gets it to 14.4 or so volts and then run the gen for another hour (smk rule--it works)
After the recharge, the battery voltage will settle back into the 12s over time depending on how much load it gets just how much time.
-If you have camped there already and have most of it figured out from before, ok. If this is a first, and you don't have a clue, we can help with a realistic idea of what you need to do whatever it is at the remote cabin for however long a time.
No idea how far a drive it is to get more gasoline or propane, whether you want to watch TV, do laptop, etc, with an inverter supplied by battery or what the heck.
So you aren't going to get much help unless you give more context, or say you don't need any help.
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: Apr 27, 2026
